04-16-2012, 07:24 AM
#2
Roof leak to electrical panel via flashing?
The roof flashing around the pipe is definitely suspect. But the weatherhead might be the culprit. It should shield the SE cable. What happens is that water gets inside the SE cable insulation, which act like a water pipe.
04-16-2012, 12:49 PM
#3
I'm 90% sure it's that funky roof jack that's leaking.
Your going to have to use a two piece, or a split one to replace it.
It's a roofing 101 job to fix it.
http://www.bestmaterials.com/SearchR...Words=retrokit
Something like one of these.
04-17-2012, 02:08 AM
#4
Thanks for the feedback. FYI, here's a pic of the weatherhead. I didn't take it while on a ladder so it's not as close up.
http://dldatastor.s3.amazonaws.com/p...eatherhead.jpg
Does the weather head look ok, or bad setup?
04-20-2012, 08:25 PM
#5
no drip loop and the leader connection looks backwards
04-20-2012, 09:15 PM
#7
Originally Posted by joecaption
Plus 1 on this ^^^^ except I am 99 % sure it is the raised flashing on the bottom allowing rain to blow under it and down the conduit hole. Great link !
04-21-2012, 12:13 AM
#8
Is wiring the drip loop and the weatherhead typically the owner's responsibility (via hiring electrician, etc.) or is it utility's responsibility?
I guess the flashing part will be the owner's responsibility.
04-21-2012, 12:20 AM
#9
Depends, In my area the power company does it to the meter.
Going to have to make some calls.
04-21-2012, 08:56 AM
#10
In my state everything on the electrical service excluding the meter of course, belongs to the homeowner..
06-29-2012, 08:19 PM
#11
Just wanted to follow up, if I had someone replace the flashing, and maybe the weatherhead, etc.
Would I find a:
* electrician
* roofer
* general contractor
I assume replacing flashing may still require dismantling the weatherhead and then putting it back together depending on how existing/current flashing is installed.
I assume electrician is the proper person to contact but wanted to confirm here.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
