-   -   Roof leak to electrical panel via flashing? (http://www.diychatroom.com/f19/roof-leak-electrical-panel-via-flashing-140406/)
daluu 04-15-2012 11:31 PM
The home I got recently had electrical panel replaced and rewired by the previous owner.
I noticed that during heavy rain (might also depend on direction of rain), that the patched up wall where the electrical panel shows signs of water dampness. See photos.
I think approximately above that panel on the roof is the connector where the utility line feeds to the home, which has a flashing installed by the shingles, though not great handywork (reused existing flashing, not new replacement).
Aside from that, the roof in that area looks ok, if not perfect. Is the utility feed line likely where the rain water has intruded?
What's the best corrective action? Replace with new proper flashing? What would you estimate that to cost hiring a contractor to do it (in northern California)?
http://dldatastor.s3.amazonaws.com/p...alpaneldry.jpg
http://dldatastor.s3.amazonaws.com/p...lpanelwet1.jpg
http://dldatastor.s3.amazonaws.com/p...lpanelwet2.jpg
http://dldatastor.s3.amazonaws.com/p...icalpanel1.jpg
http://dldatastor.s3.amazonaws.com/p...icalpanel2.jpg
http://dldatastor.s3.amazonaws.com/p...icalpanel3.jpg
http://dldatastor.s3.amazonaws.com/p...icalpanel4.jpg
Just Bill 04-16-2012 06:24 AM
The roof flashing around the pipe is definitely suspect. But the weatherhead might be the culprit. It should shield the SE cable. What happens is that water gets inside the SE cable insulation, which act like a water pipe.
joecaption 04-16-2012 11:49 AM
I'm 90% sure it's that funky roof jack that's leaking.
Your going to have to use a two piece, or a split one to replace it.
It's a roofing 101 job to fix it.
http://www.bestmaterials.com/SearchR...Words=retrokit
Something like one of these.
daluu 04-17-2012 01:08 AM
Thanks for the feedback. FYI, here's a pic of the weatherhead. I didn't take it while on a ladder so it's not as close up.
http://dldatastor.s3.amazonaws.com/p...eatherhead.jpg
Does the weather head look ok, or bad setup?
Tom Struble 04-20-2012 07:25 PM
no drip loop and the leader connection looks backwards
joecaption 04-20-2012 07:43 PM
Look at page 6 of this PDF of what it was suppost to look like.
http://www.hilco.coop/Engineering%20...OP%20SPECS.pdf
Jeeps 04-20-2012 08:15 PM
Plus 1 on this ^^^^ except I am 99 % sure it is the raised flashing on the bottom allowing rain to blow under it and down the conduit hole. Great link !
daluu 04-20-2012 11:13 PM
Is wiring the drip loop and the weatherhead typically the owner's responsibility (via hiring electrician, etc.) or is it utility's responsibility?
I guess the flashing part will be the owner's responsibility.
joecaption 04-20-2012 11:20 PM
Depends, In my area the power company does it to the meter.
Going to have to make some calls.
Jeeps 04-21-2012 07:56 AM
In my state everything on the electrical service excluding the meter of course, belongs to the homeowner..
daluu 06-29-2012 07:19 PM
Just wanted to follow up, if I had someone replace the flashing, and maybe the weatherhead, etc.
Would I find a:
* electrician
* roofer
* general contractor
I assume replacing flashing may still require dismantling the weatherhead and then putting it back together depending on how existing/current flashing is installed.
I assume electrician is the proper person to contact but wanted to confirm here.
