#1 |
roof jack and pump jack question
When attaching roof jacks, what kind of fastener (screw or nail)? Do you try to attach into trusses or structure, or can you just fasten into the roof sheeting?
When attaching top pump jack supports on the roof, what fastener (screw or nail)? Do you try to attach into trusses or structure, or can you just fasten into the roof sheeting? |
#2 | |
STAFF
roof jack and pump jack questionQuote:
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Jim |
#3 |
journeyman carpenter
i use spikes into the rafters or trusses for roof jacks
for pump jack staging we tie them in with 1/4"x 3" lags that are bolted to the sub fascia or onthe roof into rafters.. when you remove the fastener caulk the holes if going through shingles |
| The Following User Says Thank You to woodworkbykirk For This Useful Post: | BigJim (02-21-2013) |
#4 |
I find the Simpson screws work well ( they have the 1/4in head and ride enough to cover ring opening in the arm hinges and it beats trying to pry nails over)
#5 |
Mod
Roof jacks are designed to use roofing nails.
I use #10 pan head screws for pump jacks usually through the roof sheathing. 32" from the wall to the pole is my target number so I'll only attach to the fascia if there's no (or almost no) overhang.
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. |
#6 |
the only issue with using roofing nails is that the heads snap off too easy making a safety risk
| Display Modes | |
| Roof penetrations and other swamp cooler questions | tylernt | Electrical | 11 | 11-16-2012 05:04 AM |
| Pump Jack Installation Help | swiederin | Building & Construction | 12 | 08-07-2011 09:15 AM |
| Attaching Pump Jack Braces | swiederin | Building & Construction | 3 | 08-05-2011 03:54 PM |
| Jack Pump Scaffolding | ovahimba | Tools | 2 | 02-23-2008 02:34 PM |
