Roof Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-03-2010, 10:58 AM   #1
roof insulation
We have a metal roof attached directly to the roof frame with no insulation against it. We have insulated the ceiling, but the rooms that are attachments include a breakfast nook and the laundry room. When it gets really cold-like today, the washing machine water line freezes. We are considering adding foam board insulation to the underside of the roof w/ a r-10 value. Does this sound like a reasonable option????
tikecamp is offline   Reply With Quote
Old 01-03-2010, 01:30 PM   #2
Rewards Points: 5,336
The ceiling is insulated, but to what level? Are the walls insulated? Does the room(s) have adequate heat? Are the water lines on an exterior wall? Are the pipes insulated?
Really need more info and maybe some photos.
Ron
Old 01-03-2010, 02:26 PM   #3
Not sure what you mean by "what level" the ceiling is insulated, there is the pink roll insulation between the joists. The outside walls appear to have blown in insulation and the pipes were insulated somewhat. The person who built the house ran the pipes from an inside room above the ceiling to the outside wall of the addition. We already fixed a broken pipe last year and reinsulated and will eventually re-route the pipes, but are looking for the quickest fix right away. Once we remove the ceiling to get to the pipes, I can snap a few photos and post. Waiting for supplies to arrive from Lowe's
Old 01-03-2010, 02:52 PM   #4
The lowest level of insulation is over the top plates as the joist bay should be kept open to the soffit outside so cool air can get in to replace the hot air exhausted at the peak. Sometimes there is no insulation so the wall/ceiling interface is like an open window.
It would help if you answered all the questions I asked. The remote diagnosis is hard enough without as much info as you can supply.
Ron
Old 01-03-2010, 07:39 PM   #5
ccarlisle's Avatar
Oh and make sure you give us the first name and occupation of the guy who built your house, your shoe size, you lucky number - and the brand of your washing machine.
Just stick to the info we need...
Like what building code do you guess applies to you. The Canadian one? The Iraqi one? The Guatemalan one? or none of the above.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Tying new roof into old. Clutchcargo Roofing/Siding 15 11-07-2009 06:48 PM
Add insulation to solid timber roof justinNC Building & Construction 2 11-01-2009 01:16 PM
garage roof insulation between rafters denverman71 Building & Construction 1 10-21-2009 01:06 PM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 10:39 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
