Roof Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-11-2011, 10:20 PM   #1
Roof Insulation
Hello all. I rebuilt a roof section on an old house (1924). This roof only covers a closet on the 2nd story. The rafters were 2x4s and the roof had leaked for years around the chimney. I upgraded to 2x6 rafters and added a vented soffit and ridge cap. I've tried to research what would be the best way to insulate this area and have come up with little info.
I was planning on using 3/4" rigid foam as a baffle for the vent--running it the entire length from the eave to the ridge--leaving about 2" of airspace between the roof sheathing and the foam. That leaves me with only about 2 and 3/4" space left over for insulation. All the info I've researched about vapor barriers and vapor permeability has left my head spinning.
Also, instead of drywall I want to cover the closet in T&G cedar. I'm considering just jamming unfaced fiberglass between the foam baffle and cedar. Any thoughts or recommendations??? I'm in zone 4 marine (Tacoma, WA)
Roof Insulation-dscn0470.jpg   Roof Insulation-dscn0472.jpg   Roof Insulation-dscn0471.jpg
tomdor is offline   Reply With Quote
Old 10-11-2011, 11:18 PM   #2
Registered User
Rewards Points: 526
WA State has it's own Energy Code. Page 55, Climate Zone 1: http://www.energy.wsu.edu/Documents/...ers%201-10.pdf
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
tomdor (10-12-2011)
Tags
insulation , roof insulation
Shed roof addition & insulation qustion radgumbo Roofing/Siding 2 12-06-2010 05:33 AM
Adding insulation to a low-slope roof cbeingessner Roofing/Siding 25 09-21-2010 11:01 AM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
Add insulation to solid timber roof justinNC Building & Construction 2 11-01-2009 12:16 PM
New Roof and Insulation over Existing Roof MitchellScott Roofing/Siding 1 05-03-2009 08:24 AM
