Roof Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-15-2012, 09:45 PM   #1
Rewards Points: 16
Roof framing
I have a studio that I am remodeling the main room is 10'x18'. It was built in the 50's all 2x4 construction everything is 24" oc. The original low ceiling was drywall. I want to remove the 4 2x4's that run the length of the ceiling 18ft, so I can have an open cathedral ceiling. Are these 2x4's serving any purpose? Would it be safe to remove them?
mikec205 is offline   Reply With Quote
Old 02-15-2012, 10:09 PM   #2
Rewards Points: 626
Well that depends on if you want your roof to come crashing down on you? those are key parts to your truss system that is the bottom cord. Don't remove them! one thing you need to do is if you want a cathedral ceiling is replace the roof with scissor jack trusses. what you want to do is not a DIY project.
Also remove the insulation and drop it in to the bottom cord of the truss.
Nailbags is offline   Reply With Quote
The Following User Says Thank You to Nailbags For This Useful Post:
mikec205 (02-15-2012)
Old 02-15-2012, 11:22 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
In other words, those 2x4's are keeping your walls from pushing out.
The only way you could safely remove them would be to have a ridge beam that could support the full weight of the roof.
I'm in the middle of a 2-story addition right now...the upstairs is going to be vaulted ceilings....I have a ridge beam running down the center that is a PSL beam 5.25x11.25....total length is about 32' with a support in the middle.
The Following User Says Thank You to ddawg16 For This Useful Post:
mikec205 (02-16-2012)
Old 02-15-2012, 11:33 PM   #4
Rewards Points: 636
a roofer installs roofing material like shingles and metal what you need is an engineer what you have are rafters not trusses and a ridge beam is not all you would need and the person who stated if you would remove the bottom board and the walls would fall is probably correct depend on a few factors that an engineer could explain to you the best solution would be to take the suggestion about getting new trusses
jaydevries is offline   Reply With Quote
The Following 2 Users Say Thank You to jaydevries For This Useful Post:
mikec205 (02-16-2012), woodworkbykirk (02-16-2012)
Old 02-16-2012, 12:21 AM   #5
Rewards Points: 16
Roof Framing
Thanks. I think I'll leave it as it is.
Old 02-16-2012, 09:47 AM   #6
Rewards Points: 150
Good idea.
Question, did you notice any sag in the ceiling at all when the drywall was on there?
psilva8 is offline   Reply With Quote
Old 02-16-2012, 10:11 AM   #7
Civil Engineer
Rewards Points: 4,790
For future reference, the 2x4 floor joists are sometimes called rafter ties, although a better name might be wall ties. They do in fact structurally provide the lateral resistance that keeps your walls from spreading outward. I notice you have a relatively short horizontal board up near the top of the rafter. These are called collar ties. They are probably the most misunderstood structural element in your roof.
A lot of people think they act to keep the ridge from sagging, but they don't. Some people think they keep the walls from spreading, but they don't. All they do is equalize uplift forces on the roof in the event of a severe wind storm. They are important, but not crucial. The rafter ties (your ceiling joists) are crucial.
And as another point of reference, the roof system you have is typically referred to as a rafter system. Although it is technically a truss system, since the definition of a truss is a structural framework based on the rigidity of the triangle, it is not often thought of as a truss because there is exactly one triangle (formed by two rafters and the floor joist). Any roof truss system you order is going to have multiple pieces of lumber arranged in triangles, typically held together with special splice plates.
Daniel Holzman is online now   Reply With Quote
Old 02-16-2012, 10:17 AM   #8
Rewards Points: 13,748
If that insulation is installed tight up to the sheathing without foam baffles and no ridge vent the shingles will be super heated and shorten there life drasticly.
Old 02-16-2012, 06:50 PM   #9
Rewards Points: 506
Do rafters and joists form a true definitive triangle, given that the rafters are not in the same plane as the joists? I always thought this was the key difference between the two configurations (truss vs. rafter/joists)
jlmran is offline   Reply With Quote
Old 02-16-2012, 07:08 PM   #10
Civil Engineer
Even though the rafters are slightly offset from the joists, they still form a triangle for structural analysis purposes, so technically they form a one triangle truss.
Old 02-16-2012, 07:21 PM   #11
Rewards Points: 506
What about gambrel roofs which have no triangles? Are those simply rafters with joists?
Old 02-16-2012, 08:00 PM   #12
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
that sounds a little odd from what ive been taught as a licensed carpenter specializing in home construction.. ceiling joists tie the two opposite walls together which keeps them from spreadig.. by keepig them from spreading the ridge will not drop. ceiling joists are at the height of the double top plate. collar ties are in the top 1/3 of the total rise of the roof system
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Nailbags (02-17-2012)
Old 02-17-2012, 08:01 AM   #13
Civil Engineer
I was talking about the collar ties not providing the lateral resistance. You are correct, the floor joists (floor from the perspective of the attic, ceiling from the perspective of the floor below) provide the lateral resistance to spreading.
help! strange horizontal bubbles on new roof dfwnewroof Roofing/Siding 49 11-17-2012 06:46 AM
Allowable roof loads for framing plummen Building & Construction 15 01-16-2012 06:05 PM
gable roof tie in framing moonshadow Roofing/Siding 4 08-20-2009 08:03 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Need help with framing roof for sunroom diehard_1955 Carpentry 1 04-27-2005 10:24 PM
