Roof Decking - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-02-2006, 03:12 PM   #1
Malibu Mike
MIKEGOUGH1's Avatar
Roof decking
When installing roof decking, OSB or plywood, do you start at the top, ridge, or do you start at the bottom, overhang, or does it matter?
MIKEGOUGH1 is offline   Reply With Quote
Old 12-02-2006, 03:27 PM   #2
roof sheathing
Start at the bottom, easier to get a good layout, and gives
you something to stand on as you work your way up
jbob is offline   Reply With Quote
Old 12-02-2006, 04:52 PM   #3
General Contractor
joasis's Avatar
I suppose you could start at the top, but why would you want to? We always start at the bottom, and stagger the sheets up....much easier.
joasis is offline   Reply With Quote
Old 12-02-2006, 04:58 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Third vote for bottom....
This allows you to use the straight factory edge of the sheathing board as the edge of the roof = Nice and straight to attach your roof drip cap on. Your overhang and soffit line of your roof comes out nice and straight as well.
When you get to the top of the roof (Gable, hip, or other) ...it doesn't matter if it's a little wavy.... ridge vent and shingle caps cover it all.
- Build Well -
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 09:44 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
what roof decking material should i use? chrisd11 Carpentry 9 06-18-2006 09:32 PM
flat roof leak snikda9 Roofing/Siding 16 01-26-2006 04:25 PM
