Rock Veneer Install - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-25-2009, 09:44 PM   #1
Rock veneer install
Newbee here. Thanks for any input on this subject in advance. What I have is a small room that protrudes uniquely from my house. It has Hardie Panel, the 4x8 sheets, and as you can imagine real ugly. I would like to put a rock or fake rock(concrete made to look like rock) veneer on this Hardie material. I do know the normal way is to install a moisture barrier on the Hardie panel, then install the metal lath, then the mortar scratch coat, then butter the veneer to connect to the scratch coat. I hear mortar holds moisture, so the vapor barrier protects the Hardie, as it can get wet, but not stay wet. What I want to know is perhaps another possibility: Could the Hardie be coated with “something” similar to paint, but could act like a moisture barrier and then use something other than mortar to bond the veneer rock to the now sealed Hardie. The veneer I’ll be using is smooth on the back and all will be butted together so you will see a little Hardie in-between. Please give advice!!!!! Thanks
jammerjamesharm is offline   Reply With Quote
Old 03-25-2009, 10:43 PM   #2
Concrete & Masonry
Rewards Points: 620
Probably not a good idea, especially if your not grouting the joints.
jomama45 is offline   Reply With Quote
Old 03-25-2009, 11:59 PM   #3
Rewards Points: 1,232
No. Manufacturers recommendations are there for a reason.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 03:35 PM
Building a deck on solid rock time2scream Building & Construction 3 03-05-2009 07:45 PM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
Concrete driveway with rock salt finish? imola ghost Building & Construction 11 10-27-2008 12:11 AM
Landscaping Rock FEEPHEE Landscaping & Lawn Care 2 09-19-2008 04:47 PM
