Rock Foundation Bowing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-20-2009, 09:58 PM   #1
Question
rock foundation bowing
I am inheriting a house built around early 1900 or before. I am big on diy work and I noticed where the water well is that the stone foundation is bowed out . I assume it is from the recent construction on the well that helped cause this problem, My question is I intend to jack the house in the corner slightly and remove the stones, replacing the bowed pat with concrete with rebar but it will be connected with the existing stone foundation. I do not have alot of money therefore diy project. Anyone have any ideas, thanks
northern, pa
also the house is just sitting on the foundation not anchored
trucks09 is offline   Reply With Quote
Old 02-21-2009, 06:13 AM   #2
You need to have someone that understands such things to look at your problem. A bowing foundation is not good, and it needs proper engineering for a correct fix, not casual DIY patches.
Old 02-22-2009, 02:37 PM   #3
I agree but again not much money to do that. Thanks anyways
Old 02-22-2009, 08:32 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
do you really think you can get advise on how to fix what sounds like a very serious foundation problem on a diy website?Get real and call in a pro or at least somebody with the knowledge who can see what the situation calls for and can guide you on the fix, you definitely should go to your building department and see if permits and inspections are required,they most likely are
Tom Struble is offline   Reply With Quote
Old 02-23-2009, 08:10 AM   #5
more'n likely, you'll need stamp'd plans along w/an INSURED contractor,,, insurance co's don't like diy-ers when there's a claim,,, of course, if you're willing to risk it all, don't worry !
reread the post about ' permits and inspections '
yesitsconcrete is offline   Reply With Quote
Re-grading around foundation? robertr4836 Landscaping & Lawn Care 10 05-23-2009 05:34 PM
Concrete driveway with rock salt finish? imola ghost Building & Construction 11 10-27-2008 12:11 AM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 12:24 PM
concrete foundation with a crawl space agrenvik Building & Construction 1 03-25-2008 08:27 PM
