RO Sliding Glass Doorwall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-13-2010, 07:58 PM   #1
Rewards Points: 150
RO sliding glass doorwall
I have a used exterior sliding glass door wall I am putting in the rear of my house. How much larger do I make the rough opening? Is the rough opening flashed with tape like for a window? Is there anything else I need to know?
Thanks in advance to all who help.
Cossack is offline   Reply With Quote
Old 09-13-2010, 08:37 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 382
I made my RO about 3/4 inch larger for squaring door. If the door will be to the weather you will need to make an aluminum pan to go under it to keep water out.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 09-14-2010, 09:48 AM   #3
Rewards Points: 150
I assume I then shim under the aluminum frame so the doors will slide properly?
Old 09-14-2010, 12:32 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 382
I never did shim under the bottom of a door, if the floor is off then it will show big time if you shim one side higher than the flooring and the threshold strip or the track in your case will bend. The track has got to be on solid flooring for support of entire track.
Jim
Pella sliding glass door trim seperated from glass Scuba_Dave Building & Construction 6 03-10-2011 12:28 PM
Moulding Around Sliding Glass Door JRMN Building & Construction 8 08-03-2010 11:22 AM
Replacing Sliding Glass Door w/ French Doors zapatero3 Remodeling 1 07-15-2010 05:01 AM
Sliding Door Glass Replacment ryans Building & Construction 2 04-18-2007 08:49 PM
Sliding Glass Doors Drewimus General DIY Discussions 2 10-02-2006 09:06 PM
