Rim Joists Opinion...... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-23-2008, 08:56 PM   #1
Rim joists opinion......
I'm looking for some input on a rotted rim joists.
About a 4 foot section is gone above an access point for the crawl space.
2 floor joists need replacing (1 split in half, 1 cracked & on it's way out).
They are both knotched to fit in the rim joist. I've never seen this type of construction before.
I'll be sistering on new floor joists with the old. Joist hangers will be used.
2-2 x 8 sections will be used to replace the 2 x 4 & 2 x 6 that are on top of the sill. The 2 x 4 will be knocked back & they will be screwed into solid old section.
All new wood will be PT. Hangers will be galvanized.
My question is...does this seem Ok.?
As I said, I've never seen this type of construction before, but I don't see the sense of replacing it to the original.
The problem stems from a shed placed about 6 inches from the exterior wall, which will be addressed in the spring.
The sill plate is questionable if it is still good at this point, but I doubt it will be when I get further into it.
Any thoughts would be appreciated.
Thanks,
Rick
Ricki Lee is offline   Reply With Quote
Old 11-23-2008, 08:59 PM   #2
Opps....forgot the sketches
Rim joists opinion......-frim-joists.jpg   Rim joists opinion......-frim-joists2.jpg
Old 11-25-2008, 06:29 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
There really isn't a need for a double rim joist. In fact it is probably not a good idea since it will shorten the bearing footprint of the floor joists. Leave the 2x4 since it is already in place. Replace the existing 2x6 with a 2x8.
Old 11-25-2008, 07:27 AM   #4
BUILDER / REMODELING CONT
buletbob's Avatar
I believe the 2x4 was acting as some sort of header for the access below. the double 2x8 will act the same.
I don't see any problem with what your trying to do. BOB.
When I frame on a foundation I always double the rim joist over any basement windows or openings. BOB.
OH! you have a 2x6 now for a rim joist, and your going to install a 2x8 do you have the room for the 2" that you will gain, or are you going to rip them down.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 08:43 PM
help with 2nd floor joists g heil Building & Construction 5 09-12-2008 06:41 PM
Best subfloor and material thickness nugentcn Flooring 7 09-07-2008 12:48 PM
3/4" hardwood, same direction as joists? zel Flooring 13 05-15-2007 08:50 PM
