Rim Joists On A Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-02-2011, 12:00 AM   #1
Rewards Points: 1,062
Question
rim joists on a deck
should rim joists on a deck be doubled up for stability if they are braced against the girders underneath on only one side (facing inside the deck), i.e. if there is no girder overhang to fit a brace on the outer side? i am bracing the inside joists against the girders on both sides to make sure there is no wobbling (and of course on the ledger).
the PDF document i am guiding myself by doesn't say i should but i am suspicious.
Old 02-02-2011, 12:58 AM   #2
I only double up outside if I have a bigger deck but your little guy it is not needed on because your attaching to 2 fixed points. The second is you are running your joist to the same fixed points so nothing can twist on the ledgers.
proremodel is offline   Reply With Quote
The Following User Says Thank You to proremodel For This Useful Post:
amakarevic (02-02-2011)
Old 02-02-2011, 02:21 AM   #3
Contractor - Renovations
fungku's Avatar
Sometimes I do, sometimes I don't...
Can't hurt to do it on the side you're adding stairs to.
fungku is offline   Reply With Quote
The Following User Says Thank You to fungku For This Useful Post:
Old 02-02-2011, 03:00 AM   #4
agreed.
Deck Staining Nightmare steven994 Painting 6 04-06-2014 09:10 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 11:05 AM
Concrete deck -- rotting floor joists jwill Building & Construction 6 09-05-2007 08:01 AM
