Rim Joist Issue - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-04-2004, 10:52 AM   #1
rim joist issue
just started a 28' by 17.5' bedroom addition and was wondering what one does when you have a rim joist that is longer (2x12x28') than is available (2x12x24')? I figured that I would butt the ends and use a metal plate to lock the two pieces together. What's the normal practice for this situation?
thanks
JCG
grande is offline   Reply With Quote
Old 05-06-2004, 11:34 PM   #2
Split it at a joist if you're using dimensional lumber and in between joists if using i-joists. Then use another piece of rim joist to go between the joists to act as blocking and keep the rim joist straight.
hatchet is offline   Reply With Quote
Old 07-02-2004, 08:18 AM   #3
thanks
JCG
Did you get an answer to your question? I have the same type of problem.
Lorac is offline   Reply With Quote
Old 12-16-2005, 06:56 AM   #4
[IMG]rim joist JPEG[/IMG] check out your options here on the attachment
djames is offline   Reply With Quote
Cutting/drilling hole in joist - How big? curls00 Carpentry 3 07-20-2007 10:56 PM
sister a joist Jack Hass Carpentry 7 06-19-2007 06:39 PM
correct joist size for attic helpless handyman Building & Construction 1 07-06-2006 12:29 AM
Any way to allow a 3.5" bore through a 2x10 floor joist? peeks Building & Construction 1 07-06-2005 03:02 PM
