-   -   rim joist issue (http://www.diychatroom.com/f19/rim-joist-issue-150/)
grande 05-04-2004 09:52 AM
rim joist issue
just started a 28' by 17.5' bedroom addition and was wondering what one does when you have a rim joist that is longer (2x12x28') than is available (2x12x24')? I figured that I would butt the ends and use a metal plate to lock the two pieces together. What's the normal practice for this situation?
thanks
JCG
hatchet 05-06-2004 10:34 PM
Split it at a joist if you're using dimensional lumber and in between joists if using i-joists. Then use another piece of rim joist to go between the joists to act as blocking and keep the rim joist straight.
Lorac 07-02-2004 07:18 AM
thanks
JCG
Did you get an answer to your question? I have the same type of problem.
djames 12-16-2005 05:56 AM
[IMG]rim joist JPEG[/IMG] check out your options here on the attachment
