Rigid Polyisocyanurate Insulation Below Grade? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-02-2011, 01:21 PM   #1
Rigid polyisocyanurate insulation below grade?
I'm gutting a terrible basement refinish attempt by a previous owner and trying to save any building materials I can reuse. One of those materials is polyisocyanurate insulation. There are about 30 4x8 sheets behind stud walls. I'm reading mixed info about using ISO below grade. The stuff is pretty impermeable so it seems to me like putting it against the exterior wall would make a cold-side moisture barrier. Does anyone know if ISO will cause problems below grade? It's DOW Super Tuff-R 1" R6.5. Thanks.
frizbplaya is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Polystrene (DOW) Rigid Insulation board - fireproof AndrewF Building & Construction 8 11-28-2010 02:17 PM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 03:33 PM
rigid insulation under an attic storage floor? merlanvp Building & Construction 5 07-30-2010 08:32 PM
Using rigid foil faced foam insulation Ronnie1a Remodeling 1 01-22-2008 02:23 PM
