Old 09-23-2006, 05:26 PM   #1
Question Rigid foam as floor insulation
I'm converting an existing screened porch (New Hampshire) into a 3 season room. The floor is 5/4 X 6 decking which I need to cover and finish. I only have 1 13/16 to play with until I come flush with the existing threshold. I was thinking about 1" thick foil faced rigid foam directly down on that decking and then covering that with 5/8 T&G plywood. That would leave me somewhere around 3/16 or 1/4" for indoor/outdoor carpeting or some other finsh. Here are my questions:
-do I need "sleepers" to keep that foam from crushing or can I just screw the plywood down through the foam?
-if I do need the sleepers, how would you space them?
The floor is 16' across the joists by 10' deep.
Thanks for your thoughts.
Rich
rkhpapa is offline   Reply With Quote
Old 09-23-2006, 08:47 PM   #2
can you install the insulation on the under side of the floor decking?
redline is offline   Reply With Quote
Old 09-24-2006, 07:33 PM   #3
That's my problem. There isn't enough room between the grade and the floor joists for me to crawl under there. That's why I'm trying to insulate it from the topside.
Thanks,
Rich
Old 09-24-2006, 08:06 PM   #4
General Contractor
Supposedly, you just lay down the polystyrene foam insulation, then the top flooring and screw it into the joist. I've only used it under durarock and tile floor. I don't know what kind of effect it might have with a plywood top, and a space that large.
fqp25 is offline   Reply With Quote
More On This Topic
Hi this is Jon on behalf of Expert Village in this video clip we would be making our permanent shelf. First off we need to choose a piece of lumber now these are some scrap pieces that I have left from my sheet of plywood. So I just need to pick on that... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we would be laying out our shelves. Since we made each opening of our project the exact same size our shelves are all going to be the same in width. As I measure that opening I get 21 13/16... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we would be laying out our permanent shelf. Going back to our drawing we have a permanent shelf that would complete our enclosure for our storage unit so we need to go ahead and measure for... Read More »
Alright, next trick is called the creeper. What you do is you're going to throw a really strong sleeper again. I'm just going to show you real quick what it looks like. Actually, swing it out on the ground. Comes all the way back to your hand as it... Read More »
How to Cut Plywood
How to Cut Plywood by eHow.com
Plywood is a versatile wood product used extensively in shelving and cabinet construction because it resists warping and shrinking. Made from many layers of very thin wood pressed together in alternating directions, plywood easily withstands fluctuations... Read More »
why use paint brushes instead of foam brushes? joeyboy Painting 18 09-23-2007 07:52 PM
Rigid Metal Straight Threads rjordan392 Electrical 2 06-24-2007 01:42 PM
Best Ext. Sheathing: Rigid Foam An Option? austinbirdman Building & Construction 3 12-15-2006 11:02 AM
SPF Foam Roofing on Gables? WhyMeWhyNow Roofing 3 07-25-2005 07:31 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
