Rigid Foam Board Over Subfloor? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-21-2011, 08:29 PM   #1
rigid foam board over subfloor?
Wondering if I can install a 1" rigid foam board over my 3/4" plywood subfloor, and lay durock or schluter and tile on top of it.
The bathroom is over a cold crawlspace, and I could benefit from the extra 1" thickness to line up with an adjacent floor. Just wondering if would deflect at all and can support tile.
wombosi is offline   Reply With Quote
Old 12-21-2011, 08:53 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Foam board has too much give to it.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-21-2011, 08:54 PM   #3
jburd964's Avatar
Rewards Points: 166
That want work anything you put on top of foam board will constantly be moving, grout want stay and tile will brake. Ideally the foam broad would be put under the sub-floor. If you have a crawl space that's the way to go.
I'm not a professional., But I did stay at Holiday Inn Express last night.
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Drywall over 1-1.5" rigid foam? michael76 Drywall & Plaster 23 05-22-2011 03:07 AM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 07:48 PM
Insulating my attic using 4X8 rigid foam board Vermont1 Building & Construction 8 04-30-2009 11:15 AM
Venting foam board insulation mbscallen Building & Construction 5 02-15-2008 08:18 AM
Can particle board be used as a subfloor. Please help blaclightn1 Flooring 11 02-12-2008 03:26 PM
