Rigid Board And Framing Need Gap? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-30-2012, 06:17 PM   #1
Rewards Points: 131
rigid board and framing need gap?
when install framing over rigid foam that is against the concrete wall. do i need put a 1/2" or 1/4" gap between the foam? airflow or whatever purpose?
also when install rigid board to concrete. do i need leave a bit gap between board and floor? 1/2"
s002wjh is offline   Reply With Quote
Old 01-30-2012, 06:44 PM   #2
Registered User
Rewards Points: 5,492
No gap behind foam board, tight to concrete with proper adhesive: http://joneakes.com/jons-fixit-database/743
Yes, 1/4" gap under f.b. to fill with canned foam.
Air-tight drywall; http://www.buildingscience.com/docum...wall-approach/
Ask me about the ones you question; air-seal rims/add rigid foam board, fire-stop top plate and every 10' lineally, sill sealer under p.t. bottom plate, no poly, no paper faced cavity insulation, no water-resistant drywall, no foil-faced foam unless quantified.
Gary
Old 01-30-2012, 06:46 PM   #3
Rewards Points: 13,458
Leave a gap at the wall, no need for a gap at the floor.
Old 01-30-2012, 06:47 PM   #4
Rewards Points: 131
sorry i didn't make clear, what i meant is gap between the Front of foam and Stud wall. and gap between foam and floor
for the fireblock, is that include 10' for the ceiling too(after furring the ceiling, there gonna be gaps between ceiling joist)? or 10" is only for vertical stud walls?
Old 01-30-2012, 09:32 PM   #5
Registered User
I would not leave a gap at foam face/studs to help convective loops around the cavity insulation batts (unless cellulose or SPF). Fill the gap under the foam board at the slab with canned foam, you don't want any basement air getting to the concrete wall: http://www.buildingscience.com/docum...lation-systems
http://www.carb-swa.com/articles/in%...Insulation.pdf
Fire-blocking the wall every horizontal 10' apart from slab to 2x filler between wall top plate and existing house mudsill plate (if full-height concrete): http://publicecodes.citation.com/ico...002_par031.htm
Page 2: How to fireblock framing
You don't want the outlet fire in the wall getting to the floor joists cavity bays above. It will be blocked (confined) to 10 foot wide sections of wall by however tall they are.
Gary
rigid foam board on basement floor is it good or bad cutnail Insulation 6 08-29-2011 07:48 AM
(Basement) Furring strips vs Traditional framing? ctote Carpentry 15 07-21-2011 12:00 PM
How do you take old fireplace brick to new cement board? and framing questions. KlamathMog Remodeling 3 03-25-2010 10:10 AM
Board and Batten wood siding Knucklez Building & Construction 39 11-07-2008 10:38 AM
Framing on a slab floor tripower Building & Construction 2 09-06-2008 04:00 PM
