Right Way To Cement A 4x4 Post Into The Dirt - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-15-2012, 07:36 PM   #1
I love my new front yard!
Telfair's Avatar
Rewards Points: 158
Question
Right way to cement a 4x4 post into the dirt
I have a pretty good Idea but thought I should ask 1st, I got some pressure treated 4x4x8 post & plan to make a gate in my front yard.
I was just gonna dig a hole about 2 feet deep & ( maybe? place a big rock under the post? ) & then pour the cement in while trying to keep the post as straight as possible as the cement dries..?
& the repeat on the 2nd one?
Am I forgetting anything?
I tend to over think things, but this seems pretty simple, but will be the 1st time I've ever done something like this.
Telfair is offline   Reply With Quote
Old 05-15-2012, 08:26 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 840
You pretty much have it right.....
About the only thing different might be to use gravel instead of a rock....
I personally drop a little bit of gravel...then I put a thin layer of concrete...then the post.....you reduce the chances of water wicking up to the post.
Some guys may suggest a 'tube'...I think they are called "sono tubes"...it's basically a cardboard tube you put in the ground...reduces the amount of concrete you have to use....makes for a cleaner concrete chunk....most commonly used when the hole is way too big....
ddawg16 is online now   Reply With Quote
Old 05-15-2012, 09:27 PM   #3
cortell's Avatar
Rewards Points: 504
Also, consider bracing the posts in both the x and y axis. Holding the posts until the concrete has sufficiently hardened isn't a lot of fun. Also, you might think it's set enough, but if you're wrong, you'll end up with posts slightly off-plumb.
cortell is offline   Reply With Quote
Old 05-15-2012, 09:30 PM   #4
Rewards Points: 512
i'd go 3' deep and use a sono tube. put the 4x4 in the tube and pour the cement in, then lift the sono tube up about 6-10inch and then push it back down. this "mushrooms" the bottom. level up your post and ta da!
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
ddawg16 (05-15-2012)
Old 05-15-2012, 09:41 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 840
Ahhh.....neat trick....thanks
Old 05-15-2012, 10:31 PM   #6
cortell's Avatar
Rewards Points: 504
i'd go 3' deep and use a sono tube. put the 4x4 in the tube and pour the cement in, then lift the sono tube up about 6-10 inch and then push it back down. this "mushrooms" the bottom. level up your post and ta da!
Assuming you're trying to mimic a bigfoot-style footing...
When you push the sonotube back down (and keep it down, I assume), doesn't that separate the concrete in the sonotube form the concrete in the mushroomed base? If it's not continuous, I don't see what benefit that mushroomed footing has over just a straight column. The column could heave independently from all that concrete you let pour out of the bottom 6-10 inches. Just wondering if I misunderstood you.
Old 05-15-2012, 11:10 PM   #7
Telfair's Avatar
Rewards Points: 158
Well I could not wait for replies & went & just did it, seems ok so far????
I feel pretty proud of my self seems to of come out pretty good for a guy that has no clue what he's doing.
Old 05-15-2012, 11:58 PM   #8
Rewards Points: 502
make sure that water wont pool around the post.
forresth is offline   Reply With Quote
Old 05-16-2012, 12:18 AM   #9
Telfair's Avatar
Rewards Points: 158
Thanks for the tip, I'll make a slant away from it with dirt.
Moisture Barrier Behind AND on Top of Cement Board JasonCA Remodeling 0 04-07-2012 02:31 PM
wood post support of second-storied kitchen overhang mark_he Building & Construction 18 01-02-2012 08:33 PM
Fence problems-Cement or No Cement WBMill Landscaping & Lawn Care 8 06-17-2007 03:36 PM
