Ridig Foam Instillation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-31-2009, 12:31 PM   #1
I am installing 2" 2 X 8 ft. rigid foam to the concrete blocks in my crawl space. I am looking for instillation tips ie. method of attachment, cutting foam, taping seams etc.
mc3putt is offline   Reply With Quote
Old 07-31-2009, 04:15 PM   #2
motivator
Speedball's Avatar
I believe they make a special adhesive to glue the board to the masonry so it doesn't ruin the board.
Good question on the cutting tool, that's pretty thick stuff.
............Enjoy...Pat
Speedball is offline   Reply With Quote
Old 08-01-2009, 07:05 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
i use a table saw for long rips
Tom Struble is offline   Reply With Quote
Old 08-01-2009, 11:06 PM   #4
I insulated the concrete walls of my crawl space this spring.
Serrated bread knife. I wasn't able to sneak the 'good one' out of the kitchen so I used the old serrated bread knife that I bought from one of those demo sales guys about 20 years ago. He did say it would come in handy one day. Black sharpee works pretty good to mark your cut lines.
I used an adhesive caulking. 300 something comes to mind. Bought it at home depot and it was made specifically for use with styrofoam. Regular construction adhesives will eat through the foam, you don't want that.
derf36 is offline   Reply With Quote
Old 08-01-2009, 11:36 PM   #5
Rewards Points: 600
Was it PL300?
gma2rjc is offline   Reply With Quote
Old 08-01-2009, 11:42 PM   #6
Originally Posted by gma2rjc View Post
Was it PL300?
sounds about right but don't trust my memory completely. Before you buy it make sure to check the label first, it needs to be for use with styro foam.
Old 08-02-2009, 01:35 PM   #7
I always buy the can of expanding foam to attach foam to concrete!
framer53 is offline   Reply With Quote
Old 08-02-2009, 07:41 PM   #8
Yea it's the PL300 Foam Adhesive, doesn't take much to hold it in place. I went back and filled any voids/seams with spray foam as well but the adhesive makes a great sealant at the top.
Just a regular old hand saw cuts great.
Sean
sgo70 is offline   Reply With Quote
Old 08-07-2009, 09:04 PM   #9
Doesnt code prevent that rigid insulation of being installed without it being covered up?
timchi29 is offline   Reply With Quote
Old 08-08-2009, 08:40 AM   #10
I don't remember for sure, but right on the insulation is a warning to cover it up with rock.
Drywall over 1-1.5" rigid foam? michael76 Drywall & Plaster 23 05-22-2011 03:07 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Synthetic Stucco over XPS foam techinstructor Building & Construction 6 07-12-2009 09:23 AM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 09:39 PM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing/Siding 2 09-19-2008 07:12 PM
