ridge vent leaks
Originally Posted by joecaption
You never should have opened up the ridge that much.
I think that is key. If anything, you should have just added some box vents. You should always go according to manufacturers instructions (1 1/2" per side?)... To fix it, you'll probably need to rip off everything at the ridge, patch in wood and cover it as though you never had ridge vent. Then add box vents as necessary to meet your needs... maybe somebody else has an easier solution
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
