Ridge Vent Leak - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 01:15 PM   #1
Ridge Vent leak
What can I use to seal a leaking ridge vent from the inside of the attic ?
Hanlonmarcusw is offline   Reply With Quote
Old 11-30-2011, 02:09 PM   #2
kwikfishron's Avatar
Rewards Points: 998
There’s nothing you can do to fix a roof leak from inside the attic.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
ben's plumbing (11-30-2011)
Old 11-30-2011, 06:08 PM   #3
Rewards Points: 150
Any fix has to happen on the outside. Look to see if the shingles beneath the ridge vent appear sound. If this is an old aluminium ridge vent look at the ends, if I recall correctly they use to come with a plastic end piece that fit into the end of the vent, see if it is still there; also they had aluminum strips that fit over the pieces to seal one piece to another. Also look to see if it appears to remain sealed to the roof shingles. With any type of ridge vent just look for the obvious, something that doesn't look right. A photo would be useful for others to make comment on. Also, does this leak with every rain or just with a strong wind from a particular direction? If there is a pattern to when it leaks it will likely assist you in finding the cause. good luck.
TheCamper is offline   Reply With Quote
The Following User Says Thank You to TheCamper For This Useful Post:
snow country ridge vent on 2:12 pitch roof fxtm Roofing/Siding 4 11-01-2011 06:26 PM
Ridge Vent and Power Vent? etern33 Roofing/Siding 7 06-06-2011 07:06 AM
Cobra Ridge Vent cougar01 Roofing/Siding 15 04-04-2011 03:21 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
ridge vent ?'s Zel1 Roofing/Siding 6 05-19-2009 08:53 PM
