Old 08-10-2010, 11:22 PM   #1
Ridge and Rafter size
Hi guys,
I just wanted to make sure, before the carpenters finish off the dormers, that we're working with the right size lumber. The inspector was pretty flexible, but I just wanted to here from some other people what they thought.
Anyway, the dormer size (framing size) is 42.5", and the height is about 74 inches. The pitch is 6:12, and the ridge length is about 6 feet. I plan on using a 2x8 ridge and 2x6 rafters (on 2x4 wall studs). Originally I was intending 2x8 for ridge and rafters, but I think that 2x6 should be fine, and I didn't want to increase the span too much betweem the ridge and the window top.
With a flat ceiling it didn't matter about the ridge hanging down, so I figured I'd go with 2x6 rafters.
Does it sound good, guys?
Joe
Joe1. is offline   Reply With Quote
Old 08-11-2010, 01:05 AM   #2
STAFF
BigJim's Avatar
Originally Posted by Joe1. View Post
Hi guys,
Joe
Joe that sounds fine, you are on the right track.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 08-11-2010, 01:08 PM   #3
jlhaslip's Avatar
ditto
I was worried that you might be using a 'sloped' ceiling, in which case the 2 x 6 rafters would be too short to allow for effective insulation.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Rafter Calculations - help me understand, please. wombosi Building & Construction 25 09-11-2011 11:48 AM
Proper ridge vent installation Thurman Roofing 3 02-21-2010 06:07 PM
Ridge Board Support Dilemma castlerock Building & Construction 2 01-06-2009 07:57 PM
Rafter to ridge beam height JESSBRA2 Building & Construction 1 10-20-2008 04:34 PM
Ridge board enough? runningforyou Roofing 9 08-13-2008 08:43 PM
