-   -   Ridge and Rafter size (http://www.diychatroom.com/f19/ridge-rafter-size-78444/)
Joe1. 08-10-2010 10:22 PM
Hi guys,
I just wanted to make sure, before the carpenters finish off the dormers, that we're working with the right size lumber. The inspector was pretty flexible, but I just wanted to here from some other people what they thought.
Anyway, the dormer size (framing size) is 42.5", and the height is about 74 inches. The pitch is 6:12, and the ridge length is about 6 feet. I plan on using a 2x8 ridge and 2x6 rafters (on 2x4 wall studs). Originally I was intending 2x8 for ridge and rafters, but I think that 2x6 should be fine, and I didn't want to increase the span too much betweem the ridge and the window top.
With a flat ceiling it didn't matter about the ridge hanging down, so I figured I'd go with 2x6 rafters.
Does it sound good, guys?
Joe
BigJim 08-11-2010 12:05 AM
Originally Posted by Joe1. (Post 483850)
Hi guys,
Joe
Joe that sounds fine, you are on the right track.
jlhaslip 08-11-2010 12:08 PM
ditto
I was worried that you might be using a 'sloped' ceiling, in which case the 2 x 6 rafters would be too short to allow for effective insulation.
