Ridge-rafter - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-06-2008, 05:40 PM   #1
ridge-rafter
I am working on a room in an old farm house . It is a single story addition and about 100yrs old. 14' long and 18' wide. Span is 18' and run is 9'. It is a 7/12 pitch.
I took down the ceilings and discovered that there are only 4 rafters, 36" centers, no ridge board or beam just rafters tacked together at the peak.
I want to install a ridge beam 14' long x 3 -2x12's and add 2x10 rafters on 16" centers. My questions are:
1- Can I install it under the existing rafters at the peak and into the end bearing walls.
2- How do I find the measurement for the birds mouth ( if that is what it is called in this application ) for both ends as part of the new rafters will be on top of the beam and part will be resting on the sides because of the difference in width from old to new rafters.
3-Should I attach the 2x10 collar ties right under the beam or lower.
I will be leaving out the ceiling joists and using the collar tie for a flat section of ceiling. vaulted.
I know a lot will say get an engineer but that won't happen. There will be no inspection or permit way out here and the owner is way to cheap to hire one anyway.
Thanks ..sorry if to long.
caper52 is offline   Reply With Quote
Old 01-14-2008, 04:23 PM   #2
WOW!!! no replys . With all the great minds on here I thought there would be a lot of folks up for the challange. Oh well I tried.
John
Old 01-14-2008, 05:03 PM   #3
Can you post a photo?
redline is offline   Reply With Quote
How much should ridge cap cover the shingle Malcolm Roofing/Siding 4 01-09-2008 02:19 AM
Useless Ridge Vent? itwerx2 Roofing/Siding 22 10-22-2007 10:57 PM
ridge and rafters dmend Building & Construction 3 09-27-2007 10:55 AM
Losing aggregate from asphalt shingle ridge bkspero Roofing/Siding 8 07-19-2007 10:40 PM
Rafter Thrust / Cathedral Ceiling sseeley Carpentry 8 10-06-2005 12:19 PM
