Old 03-14-2011, 09:13 PM   #1
Ridge beam support.
delete
INFALLIBLE1 is offline   Reply With Quote
Old 03-14-2011, 10:10 PM   #2
Framing Contractor
Ridge beam support.
Originally Posted by INFALLIBLE1 View Post
Need to support a ridge beam 5.25"x16"x30'. Clear span want to hide the the beam in my walls so im limited to a 5.5 depth but can go as wide as needed. Can the support pole be wider than the actual beam? or is it pointless.
The beam also needs to be continuous to the foundation? Or can it sit on the top plate as long as i have a support path through the wall down to the foundation?
Had a hard time finding pictures of ridge beam support.
What does your blueprint say?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 03-14-2011, 10:16 PM   #3
Ridge beam support.
delete
Old 03-14-2011, 10:47 PM   #4
I ask the impossible!
Ridge beam support.
Typically a BD is going to go over blueprints in a plan review and they're going to be looking for blueprints prepared by a licensed engineer who will place a raised embossed seal on the original prints you are turning in with your permit application. I'm guessing you're not a licensed engineer, and most of us here are not either, and even if one of us was that person might not have enough information to answer the question...
When I hear ridge beam I think of the board at the peak of a roof... That doesn't sound like what you're talking about, is this just a beam under floor or ceiling joists and what is it supporting? If you're talking about it being inside a wall, why not just make a load bearing wall?
WillK is offline   Reply With Quote
Old 03-14-2011, 11:09 PM   #5
Ridge beam support.
delete
Alterative ways to support main beam frizbplaya Building & Construction 8 01-29-2011 12:10 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
New ridge beam support needed for cathedral ceiling? zachalyse Building & Construction 12 06-06-2010 08:06 PM
how do I support a ridge beam with a microlam onyx 1 Building & Construction 8 02-10-2010 09:48 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 02:07 PM
