Reusing Concrete Forms In Home Building - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-31-2011, 08:54 PM   #1
Rewards Points: 605
Reusing concrete forms in home building
Can I re-use the foundation forms (2x8) and, if I build a basement, plywood concrete wall forms? I thought maybe the 2x8's as rafters, ceiling joists, or for whatever comes up, and 3/4" plywood wall forms as sheathing or something.
Can this be done? Or is the wood I use for those destined for the dump?
Thanks,
Dale
dalepres is offline   Reply With Quote
Old 03-31-2011, 09:22 PM   #2
joed's Avatar
Rewards Points: 11,988
It can be done. I have seen older homes where it was obvious that the rafters were previously used as concrete forms.
Old 04-01-2011, 07:39 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
I've seen it. Concrete residue is pretty tough on saw blades though. If some-one sprays them with form oil, then they are junk.
Old 04-01-2011, 08:50 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 600
Ayuh,... I salvage ole concrete forming, All the time...
Old 04-01-2011, 10:10 AM   #5
Rewards Points: 605
Maintenance 6, your point is the big concern I have. If the boards are oiled, wouldn't that affect their ability to release moisture to the air? And what about toxins or smell?
So if they're not oiled, won't they stick to the concrete and be torn up on removal? And what about all the holes cut int he plywood for ties?
I know it sounds like I'm trying to talk my way out of re-using them but I am really not. I am hoping there's good answers for all these questions because I'd like to save the money and the answers could affect whether I go with a basement or not.
Old 04-01-2011, 11:02 AM   #6
Concrete & Masonry
Rewards Points: 526
I'd stay away from any petro based form release if it was my home. I'm not sure if you'll have much luck with re-using the plywood, as the moisture in concrete could very well lead to some delamination. As for the 2x8's, you don't really need to oil them at all, just scrape them well the next morning and they should be just fine.
Have you thought about just using concrete block for the basement?
jomama45 is offline   Reply With Quote
Old 04-01-2011, 11:34 AM   #7
joed's Avatar
Smooth 2x material dos not usually stick to concrete so bad as to tear it up. Plywood doesn't stick very often but sometimes. New material sticks less than material that has been used for forms previously.
Old 04-01-2011, 11:41 AM   #8
Rewards Points: 605
So it sounds like I just take my chances. If I have enough usable for a whole wall, then could I use the plywood for sheathing and do other walls with 7/16 OSB? Or should it all be 3/4" or none of it 3/4"?
Old 04-01-2011, 01:07 PM   #9
concretemasonry's Avatar
Rewards Points: 2,578
Since you apparently have decided on a construction method, but have you considered rent forms since many contractors also do for overloads and special jobs? That way you can built a proper home using good materials.
There are other ways to build a reinforced basement. Concrete block and ICFs are two common methods that allow more flexibility especially for unique layouts.
Dick
concretemasonry is offline   Reply With Quote
Old 04-03-2011, 11:31 AM   #10
Rewards Points: 605
Well, the bulldozer guy finished yesterday. He leveled the pad by cutting halfway down the slope to fill out a level pad about 6 feet bigger all around than the house size. This let us get a better feel for the lot than we were able to get from just looking at the elevation measurements.
The bad news is that we hit red clay about 4 feet down. I'll move that discussion to a new thread. The bottom line is that we won't be doing a basement. The leveled lot ended up exactly on the level of the clay at the midpoint. And, regardless of the clay, the result led to a decision to not do the basement. I was leaning toward the basement because I thought we'd have a 6 foot foundation wall anyway. Turns out the foundation wall will only be about 4 feet.
This still leaves us with the re-use question but now the throwaway would be half as much.
Though I am still leaning to doing it myself, I am getting quotes on having the footings and foundations done by a pro - especially since my concrete costs for the footings probably just quadrupled.
Concrete Dome Home -Q- Roofing/Siding 39 04-27-2013 05:54 PM
Building a Log Home by hand. Knuckleball Building & Construction 8 11-02-2010 07:04 PM
concrete forms for a sloping sidewalk? walkman Building & Construction 5 05-17-2009 07:54 PM
Home building process wilddngy General DIY Discussions 19 04-06-2005 03:17 PM
steps to building a home? am i correct? katerwal Building & Construction 2 03-12-2005 12:14 PM
