Old 02-07-2010, 06:52 PM   #1
Reusing Ceiling Panel As Insulator
Hi,
I'm trying to refinish my basement living room's ceiling. I removed the 30 years old ceiling panels. I'm planning to put some sound insluation between the ceiling studs (QuietZone pink fiberglass), and drywall.
I noticed that without the ceiling tiles the noise from upstairs can be very loud, and I can see that the old panels were doing some noise reduction.
Could I reuse these panels and stuff them between the ceiling studs, together with the insulation (as another insulation layer)? Would it help in noise reduction
szmaria is offline   Reply With Quote
Old 02-07-2010, 11:18 PM   #2
jlhaslip's Avatar
yes. pretty much anything helps.
what are the plans for the actual ceiling? drywall? consider using z-bar to further reduce sound transfer.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 02-08-2010, 12:39 PM   #3
Thank you for the quick answer.
We are planning to put drywall. Where can I find some description about the z-bar? Is it similar to the resilient channel?
Thank you!
Tags
reusing ceiling panel
Multiple Panel Question theatretch85 Electrical 5 12-12-2009 06:26 AM
Sub Panel SoxFan Electrical 2 12-02-2008 11:16 AM
Extending Old Main Circuit Panel lkpowell Electrical 4 10-23-2008 03:15 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
Panel Placement In Outbuilding smitty286 Electrical 3 03-31-2008 01:20 PM
