-   -   Reusing Ceiling Panel As Insulator (http://www.diychatroom.com/f19/reusing-ceiling-panel-insulator-63875/)
szmaria 02-07-2010 05:52 PM
Hi,
I'm trying to refinish my basement living room's ceiling. I removed the 30 years old ceiling panels. I'm planning to put some sound insluation between the ceiling studs (QuietZone pink fiberglass), and drywall.
I noticed that without the ceiling tiles the noise from upstairs can be very loud, and I can see that the old panels were doing some noise reduction.
Could I reuse these panels and stuff them between the ceiling studs, together with the insulation (as another insulation layer)? Would it help in noise reduction
jlhaslip 02-07-2010 10:18 PM
yes. pretty much anything helps.
what are the plans for the actual ceiling? drywall? consider using z-bar to further reduce sound transfer.
szmaria 02-08-2010 11:39 AM
Thank you for the quick answer.
We are planning to put drywall. Where can I find some description about the z-bar? Is it similar to the resilient channel?
Thank you!
