Old 11-03-2009, 02:26 PM   #1
Default Retrofit window - void between vinyl and alum frame??
hello everyone
Got a quick question in regards to the void left in between the new vinyl frame and the old alum frame. Not within the alum tracks, but the space left between the old frame and the flush fin/stucco fin. I attempted to depict the area in question with the follow image (red area). Do you insulate that void or leave it "empty" to allow water/moisture to escape??
Also, I wanted to "build" a better "foundation" for the new windows to sit. I was thinking about using low exp foam to fill the alum tracks and square off any excess foam (any foam above the highest tracks, all four sides) and then setting, shimming the retro window in place. So the window would be supported by the highest parts of the track and foam. My thought was to allow the foam to cure without the window in place to avoid any over expansion and bowing of the new windows (since I'm not a pro at foaming). This wouldn't give the window the best "seal" but could help avoid breaking my new windows from the start. Any opinion on this??
Really leaning toward the Simonton Impressions 7300 BUT I cant find someone who will sell them to me...the search continues...Thanks!
pcl586 is offline   Reply With Quote
Old 11-03-2009, 04:17 PM   #2
The replacement window should have been measured so that the window would be seated on the two sides and top. The actual window should project past these stops. There should be no space on front of the vinyl window and the aluminum frame. If you have space on the sides of the window, this is normal. There should be 1/4-3/8" on the sides for adjustment. This area should be shimmed and then insulated. If you like foam, use the low expanding product made for doors and windows.
Ron
Old 11-03-2009, 06:28 PM   #3
Thanks Ron for the feedback...the new vinyl window would be resting on top of the alum tracks (back away from the outer frame) and thus leave a void between the outer track wall and the outer vinyl fin. wouldn't it??
Old 11-03-2009, 09:12 PM   #4
This is not the way to install these windows. There is no way to keep the water out by, "filling in the space".
The window needs to be installed in a way that seals the window from water intrusion. Using a replacement window that sits in the aluminum frame might work, it depends on how you could seal it and cap the top.
You can't just get a window close in size and make it work.
Ron
More On This Topic
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. I want to talk to you for a minute about these arched windows like this. Okay we've put... Read More »
Hi, this is Jon and in this clip we will be filling our gaps. If we take a look at the inside of our door, we do have some gaps that we need to fill so that we don't get any air coming through there. To fill our gaps we are going to be using a spray... Read More »
This is Christopher Lyman with expertvillage.com and I showed you in another video that we cleaned out the tracks on this window already so now that it is wet. We want to go over the rest of the frame and make sure it is nice and clean. I like to wipe... Read More »
Storm windows are a great way to help keep heat in your home during the winter months. These thick windows also help reduce outside noise and keep moisture out of your home. Fall is a great time to install storm windows because it's usually not quite... Read More »
Car and truck enthusiasts travel hundreds, and sometimes thousands, of miles yearly to show off their prized vehicles. The stated and unstated competition centers on how well the vintage vehicles have been maintained. The goal is to restore the interior... Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
