Old 02-02-2013, 05:18 PM   #1
Retrofit Window Question
I plan on replacing my 25 year old aluminum windows with some vinyl retrofits. The window guy at the local big box store told me I would get the best fit and a slightly larger window if I cut away the aluminum flanges ( I think that it what it's called) that protrude inward from the frame and install the window directly over the frame. After looking online, I can't find any reference to this being done. Is this a good idea? Thanks.
TomJ204 is offline   Reply With Quote
Old 02-02-2013, 05:31 PM   #2
With out an inside and outside picture it's hard to know.
Old 02-02-2013, 06:24 PM   #3
I hope I attached the photo correctly. The part he says to cut away is the metal that sticks out from frame. Basically, he told me to measure drywall to drywall because I'll cut away the portion of the frame that is not embedded in drywall.
The picture needs to be rotated 90 degrees
Old 02-03-2013, 07:59 AM   #4
I would go to some place that sells only doors and windows. The big box window guy could well be a retired house painter. And for sure don't buy your windows there. They may carry a quality name (like Pella) but will not be of the same quality.
Header question - raising door and window RO enoll Building & Construction 10 05-04-2012 05:39 PM
window trim question blackestate Windows and Doors 22 09-21-2011 02:38 PM
quick door and window question wengang1 Drywall & Plaster 4 12-09-2010 05:24 PM
Retrofit Window Installation typerr Remodeling 4 10-28-2009 12:47 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
