Old 09-06-2011, 08:03 PM   #1
Retrofit window flashing question
I got a used vinyl retrofit window from a friend (see picture) and am going to install it where there is not currently a window. I have the r.o. prepared and the sheathing on the wall. The siding will be stucco. The problem is the window is a retrofit window and doesn't have a nailing-fin. How do I properly flash the window? I want it to match my other vinyl windows, which are flush with the stucco and not recessed. This will be my first remodel and I am at a loss as to how to flash this window. Any help will be greatly appreciated. Thank you.
Justin
Retrofit window flashing question-imag0064.jpg   Retrofit window flashing question-imag0062.jpg
dragondoom295 is offline   Reply With Quote
Old 09-06-2011, 09:08 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
You can't. Wrong window for the job.
gregzoll is online now   Reply With Quote
vent stack flashing question jlsdcen2 Roofing 1 05-10-2011 11:08 PM
Flashing question where eavestrough meets stucco wall? chadurban Roofing 3 12-31-2010 06:42 PM
Retrofit window - void between vinyl and alum frame?? pcl586 Remodeling 13 05-20-2010 07:24 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Replacement Window - Nail Fin Question smoenra General Discussion 12 09-04-2008 11:19 AM
