Retrofit Vinyl Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-09-2008, 05:16 PM   #1
Retrofit Vinyl siding
Looking to attach a screened porch addition to my house. When I cut the siding to attach my screen wall to the house, how do you insert and attach the J- channel without tearing out the whole section of siding? Is there some sort of J-channel retrofit that has the nail flange on the outboard side rather than inboard?
Never done siding work so be gentle!
Brown Dog is offline   Reply With Quote
Old 07-09-2008, 05:32 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I will be as gentle as possible: Unfortunatley, No. There is no J-channel retrofit for such an application.
What you must do is: Remove all the siding from that particular that will be affected. Attach your addition. Install your J-channel as needed in the same area. Then take the previously removed siding, cut to the new required lengths and install.
It's not that big of a deal. Purchase a vinyl siding "unzipping tool", remove the siding until needed for re-installation.
Example of removed siding to accomodate work area (note some siding left in place):
Re-installed with new sections:
- Build Well -
Old 07-09-2008, 05:48 PM   #3
Thats what I thought! Anyhow, one side is going to be flush with the side of existing structure. Currently, there is a vinyl corner board running down the length of the wall. So the roof will extend beyond the side(soffit), so I can terminate that leg of the cornerboard there. What happens with the other leg? Will I need to take of some siding down that way too to add a J-channel there?
Old 07-09-2008, 07:20 PM   #4
Just take enough of the ends of the vinyl siding panels off, to be able to slide your J-channel under it, and nail it off.
If you can do that, you don't neccessarily have to remove the entire sections of panels.
- Build Well -
vinyl siding over asbestos?? Buckeyes97 Remodeling 12 08-21-2012 10:20 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
