Retrofit Mudsill Anchor Bolts With - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-18-2011, 04:36 AM   #1
retrofit mudsill anchor bolts with
Hi,
I'm changing the mudsill and rim joist on my house.
Any idea on a proper way to anchor the (embeded) mudsill without interfering with the rim joist ?
There use to be a deck ledger over the sill (which is obviously the cause for the repairs )
Use something like this http://www.simpsonanchors.com/catalo...fit_bolts.html in the middle of mudsill and notch the joist sheating ?
blownbudget is offline   Reply With Quote
Old 09-18-2011, 08:54 AM   #2
Rewards Points: 5,336
That's an odd setup. Why would you expose a 2x4 to the elements? Does the sill plate sit in a recess like that? The foundation setup looks like the 2x4 sits where a brick ledge shoud be.
The setup I'm familiar with has a 2x6 PTsill plate sitting on a sill seal, with the rimjoist on the outer edge. The sheathing extends past the framing to cover the foundation interface. The floor joists sit on the 2x6 sill plate.
With your setup, the wood will rot again.
Ron
B. Franklin 1759
Old 09-18-2011, 09:09 AM   #3
Odd setup yes and . embeded sill yes. That is the hand I was delt.
There use to be a 2x8 over the silll that served as a ledger for a deck. So the at first glance (to the builder) it did not look like the 2x4 was exposed. Water cam from behind the ledger...
In the end once I cover everything up the 1/2 inch sheating, 1 inch xps, the housewrap and the furring/siding will cover the framing and that new rim joist so the wrap will also cover the 2x4 mudsill. If water comes back to the sill it will because I made a mistake higher up. The mud sill will sit on a folded 5 inch sill seal so it will not be touching the foundation from any of the two surfaces.
Old 09-18-2011, 10:00 AM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
It looks all the world to me like someone built the wall on the brick ledge, weird.
Andy.
AndyGump is offline   Reply With Quote
Old 09-18-2011, 10:07 AM   #5
AndyGump's Avatar
Rewards Points: 688
I like these from Simpson, don't know if you can use them for this scenario though.
Andy.
The Following User Says Thank You to AndyGump For This Useful Post:
blownbudget (09-19-2011)
Old 09-19-2011, 11:27 AM   #6
Rewards Points: 358
The Simpson FAP would work on the outside face if your picture is correct.
cbzdel is offline   Reply With Quote
The Following User Says Thank You to cbzdel For This Useful Post:
Old 09-19-2011, 12:15 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
Andy.
I used some of those on my existing foundation.....a lot easier to use instead of trying to drill a hole for an anchor bolt.
They run about $18/ea....but real easy to install....you drill a couple of 1/2" holes in the side....you can use wedge anchors or epoxy all thread studs in....they come with the screws for the wood but you have to buy the 2 bolts/studs.
Old 09-19-2011, 12:29 PM   #8
Bingo. Simple and effective for my application. Thanks.
http://www.strongtie.com/products/co...AP-FJA-FSA.asp
Retrofit window flashing question dragondoom295 Building & Construction 1 09-06-2011 08:08 PM
Measuring for retrofit windows mday83 Windows and Doors 5 08-14-2011 07:49 PM
How to do retrofit installation for a casement window without z-bar? forkshen Windows and Doors 1 06-22-2011 10:02 PM
Single PT mudsill or PT mudsill & sole plate on Concrete TMD Building & Construction 7 08-28-2010 10:20 AM
Hemlock mudsill foundation h2obreathe Building & Construction 3 10-29-2008 05:42 PM
