Retrofit Los Angeles - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-01-2009, 06:26 AM   #1
retrofit los angeles
Due to earthquake in los angeles i have building with soft story conditions also there were 2 tucks under apartments. so it did poorly in earthquake i need to fix them. plz provide me the related information tht where to go
jeckyjil is offline   Reply With Quote
Old 01-01-2009, 07:53 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Start by:
1.) Going to your local building Dept and discussing the matter with them. Discern what they want to see. How they want to see it. How they want this approached. Example: They may want you to bring in a structural engineer to inspect and determine (Written Evaluation & Report) - about what needs to be corrected/repaired, and how it should be done.
"Visible damage", isn't always the only damage that has taken place.
2.) Contact Reputable, Experienced, & Licensed Individuals (GC's/Contractors) in your area, and have them carefully walk thru and inspect all areas of the building, to view the structural defects and damage that must be corrected (Use the evaluation report & information from the structural engineer, if that is/was the case).
3.) Have all proposals and estimates broken down into:
a. Necessary Structural Repairs to be done: Things that a licensed Contractor should be performing. This will also include plumbing (water/gas) and Electrical. On a multi-family/Rental/Commercial building, this is generally the rule (licensed contractors must be used) in most localities.
b. Secondary Repairs: Necessary Repairs that require a highly-skilled tradesman to perform.
c. Esthetic or Minor Repairs, that do not require a highly skilled person to perform (Painting, Clean up, Light Demolition, DIY type issues, etc).
4.) Keep in touch with your insurance company about everything (extent of damages and costs).
I wrote: "Start" by....because I/we....do not truly know the extent of damage, or all aspects of the situation. I am simply providing a general course of action (without alot of additional details), based on the simple post and the very basic description of damage.
- Build Well -
Old 01-02-2009, 07:50 AM   #3
i have a 10 story building and the top floor get bit on side cz of the earthquake i was worried wht happen the whole collapse tht is y i cant risk for anyone to fullfill this requiremnt and fix the floor to its rite place. but amoung many contractor i choose this earthquake retrofitting bay area and wen they started working i felt so lucky tht i choosen the rite one for my building. so i recomend you to take help from them they are good from every perspective.
david5675 is offline   Reply With Quote
Retrofit Window Installation typerr Remodeling 4 10-28-2009 11:47 AM
Referrals for Los Angeles Area sejinro Flooring 2 07-10-2008 11:39 AM
Retrofit Vinyl siding Brown Dog Building & Construction 3 07-09-2008 06:20 PM
Retrofit Horizontal Venting roughestcarpenter HVAC 3 01-16-2008 04:46 PM
Retrofit OLD Lenox furnace? fbudworth HVAC 2 11-14-2006 06:01 PM
