Retrofit Insulation Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-15-2011, 07:11 PM   #1
Retrofit insulation question
Hi. I need to insulate A few exterior walls using a rigid foam type insulation. The walls from outside in consists of brick, fibre board (tentest?) then 3"(aprx) wood planking, covered with tar paper, furring strips and plaster board. I've removed the plaster board and lathes and will remove the tar paper. After installing 2" foam boards, lathes and tape, will I need a vapor barrier before gyproc?
I'm in Quebec. (zone 7, I believe).
Thank you.
Renognc is offline   Reply With Quote
Fixing multiple attic electrical issues before blowing in insulation darlingm Electrical 11 11-19-2011 09:19 AM
Another cape insulation question exiledgator Building & Construction 21 10-14-2011 08:42 PM
Garage insulation question trojanman1 Building & Construction 7 09-16-2009 02:51 PM
rafter insulation question Jeremy Hillary Boob, PhD Building & Construction 7 08-02-2009 08:19 AM
Insulation Question skavang13 Building & Construction 3 11-16-2008 05:08 PM
