Retro-fit Garage Floor Drain - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-30-2010, 02:46 PM   #1
Retro-fit Garage floor drain
I have been getting a lot of water pooling on my attached garage floor. the drain would be 18 feet or so from the house.
I was thinking that I would cut out a 6'X6' square and bury a 55 gallon drum with holes in it and filled with big rocks. Then pour new concrete sloping toward a new floor grate over the barrel burried under my garage floor. I live in minnesota so I think that the bottom of the barrel should be at least 5 feet down.
Does this make sense. Am I missing any important issues? Thanks for your help
Jeff Hemenway
J.Hemenway is offline   Reply With Quote
Old 01-30-2010, 02:58 PM   #2
There are very specific codes for installing a drain in the garage due to the possibility of gas entering the drain
Not sure what is required for safety
Old 01-30-2010, 05:23 PM   #3
Concrete & Masonry
Rewards Points: 636
You're absolutely correct Dave. I'd be suprised, actually amazed, if there was any form of code in this country that allowed the barrel for a drain.
Here in WI, most code dictates that the drain go directly outside to grade, and some require or allow the drain to be connected to the sanitary sewer.
jomama45 is offline   Reply With Quote
Garage Insulation DIYguy2000 Building & Construction 2 12-09-2009 07:41 AM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
