Retiling Shower Bench - HELP - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-02-2007, 02:53 PM   #1
I have a shower bench that the preceding contractor topped off with what appears to be 12"X36" slab of Corian or something similar. The top warped, I assume because the cycle of wetting and drying eventually overstressed the material that is used under this type of counter top. I was preparing to fix some cracks that are in the tile voids where perpendicular surfaces meet when I noticed the obvious attempt to "seal" the bench top with clear silicone. A few tugs on the seat and it came off without much of a fight. The installers had used eight large blobs of what I can only assume was some type of silicone sealant. You can imagine the mold and wetness left behind. The strange thing is that after removing the "glue", there was thinset that had been notch-troweled. Whether the previous homeowner wanted a slab bench or the contractor ran out of tiles and winged it, either way, the bench clearly was ready to be tiled and for some reason wasn't.
The main reason for this post is that the shower (including the bench) is structurally sound, sloped properly and other than the joints (which should have been caulked with a matching sanded grout/caulk). I have scraped a small area to see what the substrate is under the thinset. It is durorock or equal. I am wondering what would be the best way to proceed. I don't want to rip out the bench because I don't know if the pan liner covers the bench or is under it. I also don't know if they built the frame using wood or cement block.
Does anyone have a recommendation? I am going to be using tile to replace the top. Can I level out the existing thinset after removing loose debris and abrading the surface and then add a new layer to bond the tiles? Do I need to use a belt/drum sander to remove as much as the existing thinset as possible down to the backerboard? I don't have much time to accomplish this (we have twins on the way in less than 6 weeks) but I don't want to put on a band-aid that will cost me even more time and effort in the long run. I know that given how the shower was originally installed, I should be concerned that the mud pan was done correctly but that is a something I have to hope was done well because otherwise it would require completely redoing the shower. One benefit, if you can call it that there is a recessed light between the same joists on the floor below, so I can periodically check for any wetness to avert any catastrophic damage.
Sorry for the long question but I have a wife 7-1/2 months due with twins, so my Honey-Do list is long and I wanted to make sure I gave enough information for a quick and reliable solution.
Jamboy
Jamboy is offline   Reply With Quote
Old 10-02-2007, 03:24 PM   #2
This is a pretty simple fix.
Either scrape off (more likely chisel off) the remaining thinset, then use a product called red gard to apply a waterproof seal to this horizontal suface, or thinset over the remaining thinset then apply red gard.
What you do depends upon what it will take to get a tileable surface. You can't build up thinset more than about 3/8 inch and be sure of the long term results.
But red gard the surface at any rate before you tile and then retile and caulk the joints.
This is not the most bullet proof way but it is probably going to be 90% better then what you had before.
100% is to tear out some of that horizontal surface and see what is going on below, reinstall, tear off some of the horizontal tile that will but to your bench top tile and red gard the seat and up the walls 3-4 inches.
Mike Finley is offline   Reply With Quote
Old 10-07-2007, 11:56 AM   #3
Thanks for the help but one more question.
Also the same contractor used the same Corian (or similar) product for the curbs of this shower and two others in the house. They extend over the tile edge so it is difficult to see what is going on under these slabs. The curb slabs also have 3/8" glass doors and enclosures on them so it won't be very convenient to remove them for inspection.
Any suggestions? Have you ever seen or heard of anybody choosing this type of material in a shower installation?
Thanks for the advice.
Jamie Mentzer
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 02:58 PM
Retiling Shower Bench - HELP Jamboy Remodeling 4 10-09-2007 10:03 AM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 12:01 PM
