Retaining Wall Woes - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-29-2009, 07:59 PM   #1
retaining wall woes
I am rebuilding my 36" stone block wall that was pushed over this winter. I am currently excavating, and worried about erosion. Is there some thing I can do to help with that? I have heard of a material called Geo Grid, but cannot find a supply. What does this do? Do I need it, or is there another solution?
trubble is offline   Reply With Quote
Old 06-29-2009, 09:54 PM   #2
Rewards Points: 5,336
You'll need a proper base to set the wall on. You'll need a drainage space behind the wall to prevent water buildup. You'll need a landscape barrier to separate the dirt from the drainage material behind the wall.
Try searching, "retaining walls" and get a basic idea what's needed. Then go to the local masonary supply where you'll buy the materials and get their imput based on their experience with the local soil conditions.
Ron
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Replacing large retaining wall notfromaroundhere Landscaping & Lawn Care 6 12-17-2008 12:30 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
code for determining retaining wall height mrdol General DIY Discussions 2 11-08-2007 02:47 PM
