Retaining Wall With 6x6 Timbers - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-14-2010, 11:37 PM   #1
retaining wall with 6x6 timbers
Hi everybody
My question is how much 6x6 lumbers am I going to need for 2 retaining walls each 4 feet high and 50 feet wide?
Mossiliza is offline   Reply With Quote
Old 07-15-2010, 09:52 AM   #2
Rewards Points: 5,334
Originally Posted by Mossiliza View Post
Hi everybody
Using 10' 6x6's, alternating ends in the middle of the next row, You would have 9 rows high(49.5") and use 5 per row. So 45 units plus any deadmen you use to tie it into the soil behind the wall.
You will also need gravel for drainage, landscape cloth to keep dirt away from the gravel and drainage pipe to run the length of the wall. Don't forget the openings in the walls bottom to drain excess water.
You tube will have many videos on the subject.
Ron
Old 07-15-2010, 10:26 AM   #3
The 'angle of repose' of soil is about 35 degrees from the horizontal so if your wall is sloped this much it probably won't tip over.
If the wall is closer to 90 degrees it can tip or slide out, depending on the forces that it is subjected to.
Research this carefully - it's a pay me now or pay me later situation.
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Retaining wall Limapapa Landscaping & Lawn Care 12 02-09-2009 03:01 PM
Railroad Tie Retaining Wall - long wall adjacent to driveway wauf Carpentry 0 01-07-2009 09:34 AM
Going to build a retaining wall. Want to run my idea by you guys and gals keyser soze Landscaping & Lawn Care 5 03-17-2008 05:33 PM
