05-03-2010, 10:36 AM
#1
resurfacing pool? help!
Ok, a friend of mine would like to replaster his swimming pool, (OMG), he is pretty determined to do this just because the bottom is to jagged. I am the helper- can anyone help with any information on how to do this? or any products that would make a huge project a tad easier? thank you for your time
05-03-2010, 12:44 PM
#2
nothing makes it easier'n having the right tools,,, we use elec grinders w/turbo diamond cup wheels, gas/elec/air scarifiers ( walk-behind & hand-held ), & sandblasters to remove old fail'd coatings,,, after that part, its easier just more still hot dusty filthy work !
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
05-03-2010, 04:48 PM
#3
Thank you, this may be in far left but, there is really no major physical damage(holes, cracks and the such). is there a way, a tool , we could sand it all down smooth ? I understand it would still be alot of work but...
05-03-2010, 06:28 PM
#4
You talking to me?
go back and re-read the first answer. It answers this exact question
05-03-2010, 07:37 PM
#5
why would anyone want a smooth surface pool & give up the traction & slip-proofing that SHOULD be present underfoot ?
its HIS pool but i'm certain his insurance company'll look very much down their nose at such a surface,,, wouldn't be a bad idea to ck the natl swimming pool inst while you're at it !
05-03-2010, 08:22 PM
#6
Xtreme DIY'r
Inside the pool you want smooth
Around the pool - walking - should have traction
My pool also needs to be smoothed out
But it has a liner, so the liner needs to be removed 1st
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
