Resurface Concrete Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-19-2009, 02:29 PM   #1
Rewards Points: 115
Resurface concrete wall
How would I go about resurfacing this wall?
Thanks in advanced!
Carloscda is offline   Reply With Quote
Old 07-19-2009, 02:56 PM   #2
concretemasonry's Avatar
Rewards Points: 2,608
It is called dynamite or a good front end loader. - The only economical and reasonable solutions.
Resurfacing will only cover the problems for a year or so.
Dick
concretemasonry is offline   Reply With Quote
Old 07-19-2009, 03:53 PM   #3
Rewards Points: 4,656
dick usually sees the bright side of trouble,,,replacement looks like the answer to me, too
Old 07-19-2009, 06:50 PM   #4
Rewards Points: 115
Okay...
What would be the better replacement, center block or other?
Old 07-19-2009, 09:34 PM   #5
What is a "center block"? are there any other options where you are. For a low wall like that, you could use a segmental retaining wall block that does not require a footing or any mortar. It have an architectural colored split face and not a smooth face. - They are available in most countries and the U.S.
Dick
Old 07-20-2009, 03:34 AM   #6
dick, could he mean 'cinder block' or 'concrete block' ? ? ? agree the segmented retaining wall's the best choice.
Old 07-20-2009, 09:45 AM   #7
Rewards Points: 115
Cinder block is what I ment, but i'll check out the segmented retaining wall product.
Framing/drywall against uneven concrete wall? gone_fishing Remodeling 1 12-31-2008 06:44 PM
Sealing a concrete wall foundation richvoice Building & Construction 7 11-25-2008 02:55 PM
Concrete wall replaced with stick frame? jackpine Building & Construction 12 09-03-2008 04:15 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Anchor wall to concrete floor Bigman610 Remodeling 21 03-17-2007 12:15 AM
