Resilient Channel Install Around Windows And Doors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-08-2011, 07:02 AM   #1
Unhappy
Resilient Channel install around windows and doors
Hi folks... I need a spot of advice for my resilient channel install. I understand the basic principles of RC installation, but I've hit a small snag. My room has one window and one door that I'm having to work around. And both the window and the door have large (6-8"?) header blocks above them. This makes it very hard to find a good place to hang the RC without having it directly on top of the header blocks. Is there any hope for avoiding a "short" by having the screws go through the RC and into the framing?
The only thing I can think to do is to hang it anyway and just use screws of a carefully chosen length (1" for the first layer of 5/8" drywall and 1 1/2" screws for the second layer of 1/2" drywall.
Anyone have any insight on this? Thanks in advance!
Satori is offline   Reply With Quote
Aligning windows and doors papageek Building & Construction 1 11-04-2010 09:42 AM
Typical Cost to Install Anderson 400 Windows jombres General DIY Discussions 1 10-16-2009 09:57 PM
Front Home Doors Change or Cut 4 Windows Canis19 Carpentry 13 04-13-2009 06:19 AM
Stucco exterior walls - how to properly install doors and windows? vsheetz Carpentry 3 02-01-2009 10:47 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 05:04 PM
