Old 05-22-2011, 05:45 PM   #1
Residing Early 90's Ranch Home
This weekend we are going to be residing our home. Just to see how our house was built, I took a chunk of siding off.. Underneath that I found 1" Pink XPS (Assuming) hardboard insulation. I cut a chunk of that out to see what was behind it.. and I found my wall studs and insulation.. No OSB on the exterior of the house (except in the corners where they placed 4x8's. Now, I have been looking around my windows, and found that underneath them, there is just the pink 1" insulation, and no OSB, and to the sides, there is Insulation, and then OSB under it. There is no visible flashing on the outer side of the pink insulation around my windows. We haven't had any problems with our siding, or any kind of leakage with the house, we just don't like the color of the old stuff... Can we just take the old stuff off, and put the new stuff on.. or should we go a few steps further and do a house wrap over the insulation.. What do you guys recommend?
casper129 is offline   Reply With Quote
Old 05-23-2011, 10:10 AM   #2
Nobody knows anything about siding?
Old 05-23-2011, 10:30 AM   #3
"Nail-Bender"
Yes, there are people here who know about siding.
How about a couple of pictures!
What kind of siding are you going to put on?
Yeah, some kind of "house-wrap". (Tyvek)
rossfingal
rossfingal is offline   Reply With Quote
Old 05-23-2011, 10:45 AM   #4
These are some quick pictures that I snapped.
This is the current vinyl siding:
This is directly underneath the current siding:
This is directly underneath the pink insulation board:
I am going to be replacing the current vinyl with new vinyl. The house wrap would go over the current pinkboard right?
Old 05-23-2011, 11:04 AM   #5
"Nail-Bender"
Yes, the "house-wrap" would go over the "pink-board".
Make sure you tape the seams.
Use long enough nails - 1 inch insulation board - 2" to 2 1/2" galvanized/
aluminum - to hang the siding.
Float the siding - don't nail it too tight.
Keep the nails centered in the "nail-slots" of the siding panels.
rossfingal
Old 05-23-2011, 11:25 AM   #6
Thanks for the help.
Old 05-23-2011, 12:01 PM   #7
"Nail-Bender"
You're welcome!
Here's a good guide on installing vinyl siding -
(Link courtesy - "Ron")
http://www.vinylsiding.org/installat...nual/index.asp
(We didn't have that in the mid-seventies).
Good luck!
rossfingal
Old 05-23-2011, 12:04 PM   #8
Also, when removing the old siding, am I supposed to remove all of the old nails, or just hammer them in?
Old 05-23-2011, 12:14 PM   #9
"Nail-Bender"
If you've got foam insulation, and you try to pull the nails; you'll have to pad/cushion your pry-bar/hammer, so you don't crush/damage the foam.
When we do this, (and, I know this sounds like overkill!) -
we caulk all the nail holes in the foam.
It's fun!
rossfingal
Old 05-23-2011, 12:17 PM   #10
Sounds like fun - but I only have a 3 day window to get this house completed :/
Since I will be putting Tyvek over the foam, wouldn't caulking all the holes actually be overkill?
Old 05-23-2011, 12:24 PM   #11
"Nail-Bender"
Yes, it would!
We do this on other peoples house's - so, we believe in "overkill"!
However, you are right - it is overkill: since, you're installing house-wrap.
Just a suggestion!
Follow that guide!
(Also, probably OK, to just pound the nails in - we do that too).
rossfingal
Attic insulation in ranch home lchilds72 Building & Construction 6 11-29-2008 12:04 PM
How to optimize thermostat settings (2 heating systems same home) rossl56 HVAC 1 11-26-2008 04:39 AM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 10:34 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
