Residential Loft Addition - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-28-2011, 08:14 PM   #1
Residential loft addition
First off, I have a bit of carpenter experience, so I am confident in my physical ability and knowledge of the use of tools that I can complete this project myself. But, I do not have the know how for my current project at hand.
I am going to be extending the second story loft interior flooring further out (overhanging into the living room). Right now, the loft is basically a hallway to other rooms in the house. It will basically remain so, with the exception of extending the walls from the bedrooms into the hallway (so we can make the rooms bigger; which also means that we will be removing several walls within the rooms to join them together); and in doing so, we need to extend the hallway out further.
We will be replacing a normal set of straight stairs with a more compact set of spiral stairs. My main concern is of course, load bearing walls (not excited to deal with them. My secondary concern is how to extend the loft outward. Because both sides of the loft will be built inward towards each other but will not meet in the middle (because of the spiral stair case being in the middle), this may be extra difficult to complete the project while maintaining this residence to be structurally sound.
I will be getting images up very soon so you can tie my words in with what my plan is. Thanks everyone!!!
- Jacob
king_jay85 is offline   Reply With Quote
Old 07-28-2011, 08:28 PM   #2
Learning by Doing
Leah Frances's Avatar
Ambitious project! You're going to need an engineer.
Step 1 will be finding out what your local requirements are and having an engineer make a plan for you.
Keep us updated and can't wait to see pics.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 07-28-2011, 08:48 PM   #3
DIY staff
Rewards Points: 7,174
You need plans drawn to meet the structural needs of the building.
The work shouldn't be all that difficult----however plans are the first step.--Mike---
Tags
addition , loft , second floor , stairs
Twin Size Loft Bed construction.. for a dummy what_silliness Building & Construction 2 01-15-2011 02:53 PM
Thoughts on this addition? sportinwla HVAC 13 04-20-2009 04:12 AM
!!HELP!! Rain leaking between existing home and new addition NJGirl357 Roofing/Siding 4 09-10-2008 05:06 PM
How would i finish this loft???? (pics) oregonrebel Building & Construction 3 03-31-2007 08:01 AM
Home Addition cost? Russ Chewning Building & Construction 3 10-23-2006 07:59 PM
