Residential Exterior Metal Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-20-2013, 04:01 PM   #1
I have a 20-yr old home. Construction is EFIS over metal studs. I'm planning on removing EFIS and replacing with conventional plywood, TYVEK, Paper, Lath and Stucco.
Many holes in EFIS system, the latest were from the previous owner's shoddy installation of shutter track without using a urethane sealant for screws. However, lower 2 ft of stud oxidation indicates problems may pre-date this snafu. Moisture readings from between drywall and EFIS range from 40% to 90%.
Contractor indicated he can cut and replace lower rusted portion of studs and bottom channel. Two questions:
1. Would you recommend installing tar paper under the bottom channel to electrically isolate the slab from the studs.
2. Would you recommend connecting the metal framing to a buried sacrificial cathode? Any idea on what this would cost?
Thanks,
Heath
heathw is offline   Reply With Quote
Tags
efis , framing , metal studs
Framing of opening in ceiling Out2pasteur Carpentry 1 04-13-2013 04:51 PM
Clarification on cam-lock usage for private residential applications spowell71 Electrical 3 01-29-2013 02:35 AM
Basic help with window and door rough framing danf26 Building & Construction 3 08-20-2012 11:51 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
framing material estimate maydoug Building & Construction 38 06-12-2009 02:32 PM
