Old 08-27-2012, 02:35 PM   #1
(Residental) Rafter to Ridge Condition?
I recently raised an ex. section of roofing (dormer) from an 8 to a 3 pitch running along the end of the ridge on 1 side of the ridge I connected 2x6x16 @ 16"o.c.
My question is: Where the rafters meet the ridge they are above the ridge by <1" and not flush. Is this a problem? I can tell you that I used a hanger for each one and the are toenailed at the top and on the sides.
mgomez is offline   Reply With Quote
Old 08-27-2012, 04:19 PM   #2
Framing Contractor
Why are the rafters 1" above?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-27-2012, 05:02 PM   #3
Haverhill Trade 1965
Not sure what any other advice will be, but if you don't intend to change anything, cut the tips off flush with the angle of the rafters on the other side of the roof.
Duckweather is offline   Reply With Quote
The Following User Says Thank You to Duckweather For This Useful Post:
notmrjohn (08-27-2012)
Old 08-27-2012, 05:30 PM   #4
Cut the rafters so they fit. Im not liking that roof design too much TBO
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
The Following 2 Users Say Thank You to Hammer450R For This Useful Post:
Duckweather (08-27-2012), mgomez (08-28-2012)
Old 08-27-2012, 07:52 PM   #5
That should have been posted before mine. I was trying to be generous. Construction Master makes a great calculator for that.
mgomez (08-28-2012)
Old 08-27-2012, 08:05 PM   #6
In that situation i would just measure the birdmouth to the ridge and transfer it to the rafter.
Old 08-27-2012, 08:08 PM   #7
Its the 3 pitch i don't like with no support really. I can't see that not sagging under load. You have a lot of outward pressure on the front and back wall with that set up. What are your plans for that?
Old 08-27-2012, 08:10 PM   #8
Moderator
kwikfishron's Avatar
What good is a CM if they can't read a tape?
Looks like OP used the existing roof deck as his helper to hold the other end.
I'll bet the rafters are running wild on the other side with no seat cut.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
mgomez (08-28-2012)
Old 08-27-2012, 08:11 PM   #9
Also what is that span your running 2x6's on a 3 pitch?
The Following User Says Thank You to Hammer450R For This Useful Post:
mgomez (08-28-2012)
Old 08-27-2012, 08:11 PM   #10
Bombastic Idiot
notmrjohn's Avatar
Calculator? You mean with buttons and stuff and not rusty charts on a framing square?
notmrjohn is offline   Reply With Quote
Old 08-27-2012, 08:17 PM   #11
Its not a dormer, there is nothing to hold it up. No room for a collar tie.
Ridge props? lol
mgomez (08-28-2012)
Old 08-27-2012, 08:24 PM   #12
I'm not a framer by any stretch but should that ridge beam beam have been beefed up, sort of like a header.
Looks to me like it's going to sag in the middle.
mgomez (08-28-2012)
Old 08-27-2012, 09:08 PM   #13
There is still nothing really holding it up, Maybe a massive beam from end to end propped all the way to the basement...Id bet the outside walls are already leaning out.
mgomez (08-28-2012)
Old 08-27-2012, 09:09 PM   #14
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
A couple of things, I don't think you are attaching to a ridge board in the picture, it looks like blocking between rafters to me.
Also, 2 x 6 @16" O.C. spanning 16' is not prescriptive for sure. I think you need this redesigned and submit for permits.
The rafters you cut, do they continue from the ridge to a wall plate?
Where are you located by the way?
Andy.
Residential Drafter/Designer
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
mgomez (08-28-2012)
Old 08-28-2012, 07:31 AM   #15
I used the wrong hangers... I switched them at the last minute.
Tags
connection, rafter, ridge, structural
barge rafter connection to ridge wombosi Building & Construction 3 05-23-2011 11:33 AM
Ridge and Rafter size Joe1. Building & Construction 2 08-11-2010 01:08 PM
Attic Ventilation Question handy man88 Roofing 10 02-12-2010 11:50 PM
Shingling over ridge vent -details needed jogr Roofing 4 11-06-2009 06:47 PM
Rafter to ridge beam height JESSBRA2 Building & Construction 1 10-20-2008 04:34 PM
