-   -   Requirements for Sill anchors and ledger boards? (http://www.diychatroom.com/f19/requirements-sill-anchors-ledger-boards-10804/)
sandyman720 08-17-2007 01:21 PM
What are the requirements for sill plate anchors and also anchors for roofing ledger boards?
Also are straps required to tie Rim joists to sill plates?
Thanks!
troubleseeker 08-18-2007 09:02 PM
In my neck of the woods, sill plates must be have an anchor bolt within 12" of each corner and opening in the plate (door way), and every six feet in running lengths. Strapping, rafter ties, and general metal framing connections required have a lot of local variations, obviously much more stringent in coastal and siesmic areas, but even if they are not required by your local code, they are very cheap for the amount of structutal integrity they supply, and I highly recommend their generous use. I am not sure exactly what you mean by roof ledger board, so will pass on that one.
AtlanticWBConst. 08-19-2007 06:23 AM
As Troubleseeker mentioned, there are some basic standards in general for attachment locations and points, however, code requirements can and do vary by region, ESPECIALLY by Towns and Cities. Some areas are more particular and may want to see more than (above and beyond) what is required by general building codes.
You need to check with your local building dept. It only takes a phone call to find out what they want to see. Making phone calls to the local building depts is something that contractors do alot - to check on the local code requirements....
crecore 08-19-2007 04:11 PM
All good advice... Just a side note: if you're using acq treated double check that the straps or anchors are stainless or hot dip galvanized and rated for that or they'll be illegal as they will get eaten away. Most places switched all of their hardware over so you cant go wrong but I have seen places still carrying the old stuff and people, not knowing the dif., buy it because it's cheaper.
sandyman720 08-19-2007 05:21 PM
We are allowed to use galvanized.
troubleseeker 08-19-2007 08:51 PM
The operative words in Crecore's response are "hot dipped". The old "galvanized" fasteners will not last. If it is rated for the acq treatment, it says so on the box.
AtlanticWBConst. 08-20-2007 06:19 AM
Agreed: HOT-DIPPED galvanized, NOT...electro-plated galvanized.
sandyman720 08-20-2007 06:56 AM
Yes I definitly used hot dipped.
