Required Header Size For A Bearing Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-11-2012, 06:31 AM   #1
required header size for a bearing wall
removing a ten foot section of a bearing wall in a colonial home with a second floor and attict above, what size header is required
jay meny is offline   Reply With Quote
Old 03-11-2012, 07:28 AM   #2
DIY staff
Rewards Points: 7,174
Sorry, this question can not be answered without an on site visit by an engineer or architect.
No one here can answer the question with certainty ---call a local engineer for an answer you can count on.--Mike---
Old 03-11-2012, 02:15 PM   #3
Rewards Points: 1,092
"...what size header is required..." Huge. As Mike said; engineer.
Old 03-11-2012, 03:07 PM   #4
Ironlight's Avatar
You need to determine with some degree of accuracy how much load that wall is supporting. That is going to be not only a function of what is above it, but the design and construction of what's above it and how the load is distributed by the framing and/or other supporting structure. Unless you are an engineer it's fairly certain you won't have the expertise to calculate that.
In addition, 10' is a not inconsiderable span to support. You'll need specs for the supporting posts(size for steel, pcl, etc.) at each end of that span and just as importantly, an engineering solution for what is going to support those posts.
I opened up 14' of wall in our house this past fall, and in addition to needing 4 16" LVLs I needed new footings in the basement and 6" steel columns directly under the supporting posts.
Don't try and DIY on the design solution. Get it wrong and your mistake could be both expensive and fatal.
Ironlight is offline   Reply With Quote
Removing bearing wall and putting up a beam Sardinia Building & Construction 2 02-21-2011 06:11 AM
Bearing Wall Header? cbzdel Building & Construction 8 05-15-2010 10:23 PM
Can't tell what to do with this wall, load bearing?? fox_forma Building & Construction 22 09-26-2009 05:31 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Non-load bearing window header in exterior wall timelyirony Building & Construction 3 12-08-2007 04:15 PM
