Repointing Painted Brick - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-09-2008, 07:26 PM   #1
I have an old farm house (100 years or so) and the brick needs repointing but 25 years ago my Dad thought it would be a good idea to paint the brick instead. Now I oen the place and I want to repoint the brick but my neighbour says I cant cause its been painted. Is this right?
porkyfarmer is offline   Reply With Quote
Old 02-09-2008, 07:56 PM   #2
ICF Construction
You are going to have to remove the paint in the areas where you plan to repoint, morter will not stick to paint...for very long
Chris
Chris Johnson is offline   Reply With Quote
Old 02-10-2008, 11:18 AM   #3
So I guess I will have to get the house sand blasted to remove the paint, since the whole house needs to be repointed. I am guessing that sandblasting and repointing isnt goin to be cheap I might as well just get the house stuccoed or will stucco not stick to paint either?
Old 02-10-2008, 04:00 PM   #4
Rewards Points: 1,232
How can you tell it needs repointing if it is painted?
Tscarborough is offline   Reply With Quote
Old 02-10-2008, 04:27 PM   #5
The bricks falling out and the motar missing between the bricks. It should have been repointed 40 years ago , long before it was painted.
Old 02-10-2008, 06:19 PM   #6
It certainly should not have been painted. If you sandblast the paint off, you should also use a sealer afeter repointing, since the sandblasting will most likely ruin the brick.
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 04:26 PM
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 03:07 PM
Dryvit or Stucco over Existing Painted Brick andrew2008 Building & Construction 4 03-22-2011 06:58 PM
Painting over painted exterior brick kbrooke Painting 9 07-27-2009 09:27 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
